1986 to 1986 motor swap
Old Apr 8, 2009 | 10:53 AM
86&94's Avatar
I have a 86 sport coupe with 2.8 and T5 , bought a 86 i-rock with 305 tpi and 700r4. Was wondering how the computer issues are going to go seeings how chevy did not put out that configuration due to fuel boiling issues, and how would I get around that. Any help would be apprecated
Old Apr 8, 2009 | 10:56 AM
86&94's Avatar
Re: 1986 to 1986 motor swap
Sorry wanting to put 305 with the manual trans.
Old Apr 8, 2009 | 11:46 AM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
In 86 you could get an iroc (not i-rock) with a manual trans if the car came with a carb. It would be a lot less work to put the manual trans in the iroc. I think you'll still have to do some computer tuning or swap out the chip for the manual trans. If you are going to put the 305 in the V6 car you're going to have to swap out not only the engine but the wiring harness and computer.
Old Apr 9, 2009 | 08:26 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
You want a 305 with a manual trans? Ok first sell v6 car. Buy complete 5 speed setup for a v8 and swap in. Or pull engine, trans, wiring harness, and pcm from v6 car, sell it cheap. Buy a complete 5 speed setup for a v8 (the pedals from your v6 setup would work). Swap wiring harness and pcm over to v6 car, swap in engine, swap in 5 speed setup. The v6 tranny uses a different bellhousing and input shaft which won't work with a v8 engine. You didnt mention what kind of induction your v6 has, chances are you will need to drop the fuel tank, replace the pump and fuel lines. Either way unless the Iroc is a complete pos it would be easier to just swap a 5 speed setup into it. Get a v8 trans. Don't worry about fuel boiling issues, tpi 5.0's and 5 speeds came from the factory togather, just not all years. It was probably more of an issue with getting it certified than anything else.
Old Apr 10, 2009 | 11:02 AM
86&94's Avatar
Thanks guys for your help. Feeling a little discouraged,I have a 1986 t top sport coupe 2.8 t5 mpi with 50,000 miles no rust (down under) it sat in the sun for 8 years and got the paint baked. Also have a 1986 t top irock z with 305 tpi 700r4 with a pile of miles (187000) a little rust here and there but still looks and runs great(needs alternator). Thinking about selling or trading for one car.Still think I have a nice setup,just a lot of time and work, thanks again for your time.
Old Mar 15, 2011 | 11:30 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I just looked up a Vin # on a 86 Iroc I am buying and the specs said 5.0L V8 MPI
The guy said it is a TPI, Is there a difference? And is this a good motor. please answer soon, I buy on Friday
Old Mar 16, 2011 | 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
TPI (tuned port injection) is a MPI (multi port injection) system. When you open the hood just make sure that it looks like there is a giant metallic spider sitting on top of the engine.
RBob.
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
