Need pointers on replacing oil pan gasket in car
Old Jul 28, 2018 | 09:31 PM
3tas4me's Avatar
I am in the process of replacing the oil pan gasket on my 1984 L69. I already removed the starter, distributor cap, motor mount bolts and y-pipe from the manifolds. I have lifted the engine on the balancer but still cannot get the oil pan out. wants to hit on the bottom of the bellhousing (5-speed car) when trying to tip it down to remove. What am I doing wrong?
Old Jul 28, 2018 | 10:56 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Need pointers on replacing oil pan gasket in car
Try rotating the crankshaft, after marking the dizzy spot. Mine was stuck as well on something, rotated the shaft, and it fell out by itself.
Old Jul 29, 2018 | 09:39 AM
3tas4me's Avatar
Can you describe what position the crankshaft should be in?
Old Jul 29, 2018 | 10:00 AM
Keyway straight down... which is, 135° (3/8 turn) CW from #1 TDC
Old Jul 29, 2018 | 10:07 AM
antares57's Avatar
The lobes on the camshaft have to be in the up position, or at least ones nearest the front of the engine. They were binding with the pan when I tried to remove mine.
Old Jul 29, 2018 | 12:36 PM
3tas4me's Avatar
Got it out finally! I am using the Fel-Pro one piece gasket in hopes to never have to do this again!
mikasa337
Jul 28, 2018 05:28 AM
musclecar70sfan
Mar 19, 2016 11:45 AM
BlackTopKing
Jun 16, 2015 07:17 AM
Dougie91
Sep 22, 2012 10:40 PM
