Replacing oil pump, need some pointers.
Old Jul 26, 2018 | 05:35 PM
mikasa337's Avatar
So, I have had a problem with some bad oil pressure recently and decided to just put a HV oil pump in. Has anybody done this with the motor in the vehicle? I need to get this in ASAP. My Camaro is a 1985, z/28, with a 305. I've already purchased the pump and oil pan gasket.
Old Jul 26, 2018 | 05:51 PM
Re: Replacing oil pump, need some pointers.
Yup...
DON'T.
Pull the motor. You'll be glad you did. Not least, because it'll take less time; but also, because you'll have a better chance of being able to get it back on leeeek-free.
But the question MUST be asked: WHY are you replacing the oil pump AT ALL? That part almost NEVER goes bad in a SBC. As close to NEVER as it can be, and it still have happened ... once.
Old Jul 26, 2018 | 06:04 PM
mikasa337's Avatar
It lost oil pressure, I cant get any out of it unless you count to 20psi it gets on startup. It's starting to knock pretty bad. Do you think it could just be a clogged galley?
Old Jul 26, 2018 | 06:17 PM
No.
And before you ask, no.
Needs a crank, maybe some rods. Bearings of course.
You're DEFINITELY wasting your time messing with the oil pump and thinking you're gonna put it back together and it be OK. That's fantasy land.
Old Jul 26, 2018 | 07:34 PM
GeneralDisorder's Avatar
Agree with sofa on this one. I build engines for a living - you will accomplish absolutely nothing (you won't even increase the oil pressure) by changing out the pump.
Remember - the pump doesn't provide ANY pressure. It provides flow, and pressure is achieved by the resistance of that flow through the bearings and lubrication passages. So trying to change the PRESSURE, by changing the thing that creates FLOW and has ZERO effect on the PRESSURE won't work will it? That would be like changing a fully charged battery because your alternator isn't charging. It would be basically an exercise in futility.
Just get a crate motor - it will be cheaper than trying to rebuild that one unless you happen to have a machinist in your pocket and some extra unmolested parts laying around. I'm guessing probably not.
GD
Old Jul 26, 2018 | 07:38 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
No oil pressure and knocking = blown up motor.
Your engine is done.
Old Jul 26, 2018 | 09:32 PM
mikasa337's Avatar
Yeah but it's only an upper motor knock so the lower motor must have some pressure right?
Old Jul 26, 2018 | 11:42 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
If you lost oil pressure then the space in your lower end bearings is too large. Even with a HV pump you wont see an increase in oil pressure and you will be wasting time and money.
stop and google search it.
Old Jul 27, 2018 | 12:01 AM
Please define "upper motor"
How do you know what is knocking?
GD
Old Jul 27, 2018 | 03:12 AM
88IROC-USA's Avatar
Car: 1988 IROC-Z
Transmission: 700-R4
Axle/Gears: 2.77 Positrac
That's pretty funny!
Old Jul 27, 2018 | 08:14 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Sounds like your motor is on its way out. If it was me I would start searching for a good deal on a crate and shove in some 20W-50 to try to boost the pressure for the next couple weeks before the swap.
Old Jul 28, 2018 | 05:28 AM
6998poncho's Avatar
Car: 1998 Firebird Formula M6
Engine: LS6 installation finished 8-17-2011
Axle/Gears: Stock 3.42 Ratio
When you take apart the crank bearings you will probably see surfaces that look like they spun on the edge of a file instead of mirror-polished surfaces. Replacing the oil pump is an exercise in futility. Time for a replacement engine. No band-aids this time. Years ago I helped a co-worker in the same situation.
rads84n94camaro
Jul 6, 2008 09:44 PM
GTAwheelman
Mar 14, 2008 12:42 PM
91blue_fire
Sep 2, 2005 06:25 PM
92RS shearn
Aug 17, 2001 07:46 AM
