Runs great but no power
Old Oct 11, 2018 | 09:56 PM
  #151
ULTM8Z's Avatar
Re: Runs great but no power
Originally Posted by T4Turtle
Yes I have my power back under more than 40% throttle.
Setting this way I used a vacuum gauge connected direct to intake vacuum, then advance timingby twisting the distributor counter clockwise and watch the vacuum and stop at the maximum value then back off a little. Be sure to have EST wire disconnected while doing this, then clear the code 42 you should get from running with EST disconnected. You will want to have a scan tool to watch for knock afterwards.
so you don't actually know what your case timing is set at?
Old Apr 25, 2020 | 09:04 AM
  #152
T4Turtle's Avatar
Car: 1987 Fiero GT
Transmission: 5 speed Getrag
This power issue is solved. The mufflers were internally collapsed restricting the exhaust flow. I did do an exhaust back flow test but obviously this should have been tested under load. I would have had to setup a camera to be able to record the gauge under load, wish I had tested this way it would have saved me a lot of time.
Jim at TPiS figured this out. I stored my car there over the winter as I needed my garage space for remodeling. I told him to take a look at it and he could not get it to go over 3100 rpm on the dyno. He saw the mufflers bulging and cut them out and put straight pipes in place of them. Then he tuned it on the dyno and I now have a normal 350 tpi engine and it is a blast to drive again!
With the 2" exhaust it is not that loud and no droning on the freeway or at any rpm. I am going to get a look at what I have to work with for mufflers as it is a pretty tight space where the old ones go and they were very small mufflers.
I just wanted to put some closure to this thread for someone searching for similar power issues in an otherwise good running vehicle.
Old Apr 25, 2020 | 01:54 PM
  #153
ULTM8Z's Avatar
Wow, I don't think we would have ever diagnosed that over the internet... glad you got it solved finally!
Old May 4, 2020 | 06:06 PM
  #154
T4Turtle's Avatar
Car: 1987 Fiero GT
Thanks ULTM8Z, you were a lot of help an are a great contributor to this forum.
Looksthakill
Alternative Port EFI Intakes
Oct 9, 2011 11:01 PM
bjm1206
Jul 17, 2010 05:50 PM
camarogundam
May 30, 2009 08:06 AM
woody's89
Dec 4, 2007 11:47 AM
