cruise control adjustment? seems jerky
Old Aug 16, 2018 | 12:46 PM
rocn7roc's Avatar
Hi I have a 91 Camaro with an 86 L98 TPI ,got it all running and tried the cruise it does work but seems jerky at highway speeds.It accels to hard lets off does it all again. Is there some adjustment I can make for this Thanks Mike
Old Aug 16, 2018 | 12:51 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: cruise control adjustment? seems jerky
No adJustment really, but check and see if the line to the vacuum ball in the fender is there and good. Sounds like a vacuum leak.
GL!
Old Aug 16, 2018 | 12:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the car wasn't originally a L98 get a cruise module from a L98 car and swap it in. The cruise module is a plastic box under the dash.
RBob.
Old Aug 16, 2018 | 03:25 PM
rocn7roc's Avatar
Old Aug 16, 2018 | 03:29 PM
rocn7roc's Avatar
Thanks On another issue is there any way to test to see if my purge cannister may of gotten deleted when it was reprogrammed for vats and Egr delete . Smelling gas fumes on hot days. Thanks Mike
devilfish
25
Jun 9, 2004 04:25 PM
OUTATIME GTA
Jul 4, 2003 03:31 AM
OUTATIME GTA
Jul 4, 2003 02:26 AM
88TAJeff
Nov 4, 2001 05:57 AM
