rough jerky idle, engine shakin' -help!?
Old Jul 4, 2003 | 12:25 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
car runs great over 1000rpms, only when it comes to a stop it idles pretty rough bouncing from 500-800rpms and jerks forward a little bit. stalled on me a few times to w/a check eng. light, starts right back up. popped the hood and the engine is shakin' quite a bit. the IAC was disconnected and it smoothed out but idled at 1500 which does me no good. might it need to be replaced? what else could it be? i think a couple of my injectors are lame too, could that cause it? any help is appreciated, thanks!
Old Jul 4, 2003 | 12:50 AM
Ragtop89's Avatar
Seriously, sounds like a bad miss.
What have you RECENTLY done to the car? Let's start there.
Check:
plugs and wires
cap and rotor
Nothing wrong?
Check your valve lash.
Check fuel pressure.
Old Jul 4, 2003 | 12:51 AM
Morley's Avatar
Clean the throttle body, idle passages, IAC and throttle blades. Then check your injectors for leaking. if all is good, set the minimum air as described in the tech article here.
Old Jul 4, 2003 | 01:23 AM
Car: '89 GTA
nothing done recently, just changed the oil and got new plugs, i do have 1 spark plug that seems to have fouled 2x so far.
cap, rotor & wires are stock still.
fuel pressure is good.
throttle body was cleaned out a month ago.
how do i check the injectors for leaks?
anything else it could be?
Old Jul 4, 2003 | 03:31 AM
Morley's Avatar
Injector balance test, this will spot any leaking or plugged / non firing injectors. Use this to do the job and many more http://www.actron.com/cgi-bin/web_st...=1016845_14189
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Bradsaundry
Aug 12, 2015 12:34 AM
