Speedometer Working Sometime
Old Jan 7, 2002 | 10:30 AM
larryddodd's Avatar
I have a 1991 Camaro RS with a 3.1L engine. Sometimes the speedometer doesn't work. It seems like when it is cold out that the speedometer doesn't work and then all of a sudden it will start to work but bounce up and down. Then it will settle down and work correctly. It takes about 10-15 minutes of driving and it will start to work. I would like to get this fixed so I won;t get a ticket before the speedo starts to work.
Old Jan 7, 2002 | 02:08 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
usually indicates it needs lube
graphite.. but it is a pain. you have to lube it from the top.. as in by taking off the cable behind the speedo.
Old Jan 7, 2002 | 02:38 PM
larryddodd's Avatar
Can I just pull the cluster out of the dash and remove the cable that wayor is there some other way to do it. If so do I just put it back in from the top or is there something else that I need to do?
Old Jan 7, 2002 | 03:37 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You don't have a cable speedometer you have a 91. You are probably going to have to replace the gauge. Lubing it may help a little but if that doesn’t work just need to replace it. You can buy them for cheap off ebay.
Old Jan 7, 2002 | 03:44 PM
larryddodd's Avatar
How would I go about lubing the speedometer? Is there a special tool or something?
Old Jun 24, 2013 | 09:51 AM
dallasboy995's Avatar
Car: 1991 B4C Camaro
Engine: 350 auto
Re: Speedometer Working Sometime
I'm having a similar problem my speedometer only works sometimes its as if something is loose, update the thread if you have any results changing your guage
Old Jun 24, 2013 | 09:59 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
When did the Camaro ditch the speedo cable 90 or so?
The birds did away with them in 86 or so??
sounds like you need to remove the speedo sending unit on the side of the trans and check out whats going on in there.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
