Oil pressure gauge is screwy
Old Sep 16, 2018 | 07:49 AM
sgeorges714's Avatar
Car: 1987 Z28 Vert Special Edition
Engine: 305 TPI LB9
When you immediately start the car the gauge works fine and is reading between 30 and 35 PSI. After it warms up a little bit, it goes down to 10 or 15. Then it starts going wacky going from 0 to 60 at a million miles a minute. Already change the sending unit twice. Put a manual gauge up to it and it's reading fine. Is it my gauges? Or is it something else? I need some help on this guys
Old Sep 17, 2018 | 09:09 AM
Orangeuscrd's Avatar
Car: 1992 Firebird Formula
Engine: 5.7 TPI
Transmission: 700R4 4SPD Auto
Re: Oil pressure gauge is screwy
I have 92 formula, and mine does the same thing. cold start it's at 30-35 once warmed up it's around 10-15 but it's not bouncing all over. I was wondering myself if that normal to go that low. I just got my 3rd gen about a month ago so i'm new to it.
Old Sep 17, 2018 | 09:28 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Sounds like the gauge is going bad, or there is a wiring problem, maybe a ground issue
Old Sep 17, 2018 | 11:22 AM
GeneralDisorder's Avatar
My excellent condition 86 LB9 is over 60 psi at startup, and never drops below 25 at a hot idle (600 RPM). I run 10w40 Amsoil PP. But a single weight of oil thicker isn't going to bump it 15 psi either.
Test with a calibrated mechanical shop gauge if you really want an accurate reading. The general rule of thumb is 10 psi per 1000 RPM of engine speed but generally in my experience if it's below 20-25 psi at a hot idle your clearances are opened up.
GD
SilverSub122
Jul 25, 2002 05:02 AM
SilverSub122
Jul 24, 2002 02:36 AM
sinner
Jul 15, 2001 04:42 PM
89GTA5spd
Feb 8, 2001 07:12 PM
CamaroX84
Jan 11, 2001 01:24 AM
