700R4 RPM 2500 @ 70/75MPH Normal?
1 Post
Car: 1992 Firebird Formula
Engine: 5.7 TPI
Transmission: 700R4 4SPD Auto
Hello,
Asking if this is normal, my birds running at 2500 RPM around 70/75 MPH with 700R4. I just had the trans rebuilt it's got a 3.23 rear end. It ran like this before having rebuilt as well.
Re: 700R4 RPM 2500 @ 70/75MPH Normal?
FWIW, mine (700R4/3.23) turns about 2050 at 70mph on stock-size tires (245/50-16). I have verified the speed accurate to +/- 1.5 mph. I have not verified my tach, however, the gear ratio speed calculator (http://www.apexgarage.com/tech/gear_ratios.shtml) calculates this to be about right. Are you running different diameter wheels/tires than stock? According the speed calculator, 2,500 rpm with stock (25.6-inch diameter) tires and .70 overdrive/3.23 final drive ratio, you should be going 84 mph.
Car: 1987 Black IROC-Z (SOLD)
Easy check for correct RPM.s & speed with the 700R4. In OD the tach @ 1000 RPM.s and the speedo @ 40 MPH....at a steady speed.
Car: 89 Firebird
Engine: 355 TBI
Are you positive it's still got the stock 3.23 gear or maybe it has been swapped for 3.42s?
383firebirdokc
06-16-2011 10:02 PM
