idle problem 91 5.7 tpi
Hi to all .
I have a Z28 year 1991 5.7 TPI
The car sat in the driveway for a whole year and had gone well before.
This week when I was chraing to moved it the car was cold and the columns were high , when I switched to DRIVE mode
The engine goes off and so on every time I switch to DRIVE.
I changed the sensor's TPS and replaced the sensor of the AIC and still have the same problem I cleaned all the throttle with material and it did not help.
When the engine heats up, it can not hold columns and goes idle.
Need help please.
Need help please.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: idle problem 91 5.7 tpi
I’m betting there’s varnished fuel/deposits in the injectors.
Car: 1991 Z28 1LE
M G Brewer
Aug 18, 2017 10:02 PM
