Fuel Siphon Hose Stuck
Old Oct 3, 2018 | 09:12 AM
Rgiroc's Avatar
Car: 1989 IROC
Engine: 5.7
So I decided to siphon some old fuel out of my 89 IROC. Got the hose down into the tank from the filler cap and now I can't get it back out. Seems to be stuck on something. Is there some anti siphon valve or something it could be caught on? If so where is that located exactly? Any suggestions?
Old Oct 3, 2018 | 10:05 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Fuel Siphon Hose Stuck
The only thing I know that could be hanging up, is the little flipper at the filler hole. Take a little screw driver or piece of wire at the top of the filler hole and keep the flipper from binding. How big of a hose did you use? (Diameter)
Old Oct 3, 2018 | 10:43 AM
Rgiroc's Avatar
Car: 1989 IROC
Engine: 5.7
Well I got it out after messing around with it for an hour. Seems there is some type of flapper or anti siphon device somewhere in the filler line between the cap and the tank itself. It was not hung up on the t flapper at the cap, it was down below that.
Old Oct 3, 2018 | 10:44 AM
Rgiroc's Avatar
Car: 1989 IROC
Engine: 5.7
What is the best way to drain the tank aside from siphon fro the filler cap neck?
Old Oct 3, 2018 | 10:54 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Pull the filter and power up the pump at the relay and pump it out
Old Oct 3, 2018 | 11:31 AM
red rock's Avatar
Car: 1987 iroc
That very well could be. I never was very good at siphoning gas, I always paid for mine.
Old Oct 3, 2018 | 06:11 PM
Drew's Avatar
Punch a hole in the bottom with a screwdriver and hammer.
The filler neck isn't hollow. The only tube small enough to actually make it into the tank will flow so little gas, you'll be there all day. Not to mention that unless you can turn a 90* corner once you're in the tank, you're not going to siphon much more than the top half of the tank. You're chances of hitting the sump are slim and none.
sharky55
Mar 25, 2012 03:47 PM
a1bertmarkovski
Jun 13, 2011 01:35 AM
MiZZiE
Aug 25, 2009 07:06 PM
WhiteHawk
May 7, 2006 01:04 PM
Mkos1980
Nov 21, 2001 11:18 AM
