siphon question and gas issues
Old Jun 10, 2011 | 08:38 PM
a1bertmarkovski's Avatar
Car: 1988 Camaro iroc z
Transmission: manual
ok so my 1988 iroc-z 305 camaro has been sitting for 10 years so im assuming the gas is bad and thats a reason it is not running right. can i siphon the gas out from where the gas cap is or is there a safety mech inside to prevent that? also it smells like raw fuel when i give it gas like it is not burning it. could this be timing? or bad injectors? the idle is shaky and it seems like it is not running on all cylinders. im doing a tune up tomorrow to hopefully free some problems but i would also like to get that bad gas out! any suggestions? Thanks!
Old Jun 13, 2011 | 01:35 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: siphon question and gas issues
IMHO, after 10 years, the way to do it correctly is drop the tank, have it boiled out, flush/blow out the lines and have the injectors professionally cleaned.
watajob's Avatar
Car: 92 T/A 'vert
And, of course, a new fuel filter.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
