new gas tank problems
Old Jan 7, 2002 | 06:41 PM
Eightyninef's Avatar
I have a new gas tank, and I'm looking at it and it doen't look so new.
where the filler neck meets the tank is all greasy. It looks like gas stains is all around the seem, kinda like my old leaking tank, but not as bad. I'm trying to figure out if this could be from them welding the filler neck to the tank.
The retainer ring welded to the top of the tank has welding slag all over it. The OE tank has all perfect tack welds. so I'm not even sure it will seal correctly.
I had this tank sitting on my work bench for 6 months. Dal said he would exchange it. can't ask for better than that.
just a little annoyed,
Larry
Old Jan 7, 2002 | 10:11 PM
Vader's Avatar
LB,
I would at least compare the "new" tank to another "new" tank to make sure you weren't getting corkscrewed. Is this a GM tank or aftermarket?
Old Jan 8, 2002 | 08:43 PM
it's a new GM tank. with the deeper plastic "sump"
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
