Non Thirdgen, Non Automotive, Floor Jack Problem
Old Jan 5, 2002 | 10:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The jack is a 3.5 Ton, about 3 years old. The problem is after jacking up something I can hear it little by little coming back down. Is that because of the pump(seal) , low on fluid or soemthing else? thanks
Old Jan 5, 2002 | 10:45 PM
BAK12484's Avatar
have you ever left the jack in your garage during the winter?? not a good idea at all as it can destroy the seals and make your jack useless
Old Jan 5, 2002 | 10:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I keep all my jacks in the garage in the winter. I am not going to carry that 50lbs jack up and down stairs. i have 3 little 2 tons that are almost older then me and they work fine.
Old Jan 6, 2002 | 05:36 AM
ede's Avatar
ede
check the fluid level, but i'll bet it because of the cold. i had a hein-warner 2 ton jack, professional quality, that wouldn't work in the cold while my 65 dollar auto zone special always works.
Old Jan 6, 2002 | 06:32 AM
poncho9789's Avatar
If it is coming down it is probably the seals. Hay ede I am having to have an hein-warner rebuilt right now it will jack up about 3/4 and then come right back down it is leaking from the pump seal. Man parts for those things are expencive.
Old Jan 6, 2002 | 11:22 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
May just need to bleed it...some have a plug to crack, some you open the fill plug on. Bleed instructions should be on the jack.
Might also be a good idea to get some hydraulic fluid incase it leaks out.
Old Jan 7, 2002 | 04:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
We had a jack like that... it was really old, we tried bleeding it, didn't work- so we bought a new one. It's been in the cold garage for the past 4 years, and still works like a charm.
Old Jan 7, 2002 | 11:54 PM
85 Berl's Avatar
Mine's been outside in the yard for 3 years, and it still works great.
Old Jan 8, 2002 | 09:39 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I have a small floor jack and a couple of bottle jacks that have resided in my garage for about 15 years. They still work fine and we get some cold winters. Although I recently got a new 3 ton floor jack which I'm luggin back downstairs every time I'm finished using it.
customblackbird
Aug 15, 2021 10:16 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Amillionoh7
Aug 7, 2015 01:24 PM
