Three tubes, two connections. huh?
Old Dec 8, 2018 | 06:57 PM
Brian Ochoa's Avatar
Car: 1989 Firebird SSA
Engine: 2.8L V-6
Axle/Gears: Stock
So I'm 99.4% sure I have a vacuum leak and decided to trace out some hoses to see if any of them need replacing. So far pretty much every hose I've found has been pretty rotten but I digress. Traced out one hose that started at a fitting at the back of the intake plenum to something else next to the washer fluid reservoir.
I have no clue what this thing is but here's the real mystery. The hose had a T-junction that went to... nothing. Seriously, it was just lying in the battery tray connected to nothing. Try though I might I could not find an empty fitting within reach of the hose and finally just gave up and routed an extra long hose to the two fittings and parked the car.
Any idea what the above part is? And for that matter what the T-junction was supposed to be connected to?
Old Dec 8, 2018 | 07:04 PM
mwill316's Avatar
Car: '88 GTA
Re: Three tubes, two connections. huh?
This diagram should help you
Old Dec 8, 2018 | 11:23 PM
Drew's Avatar
If the diagram is unclear, the Sphere of Destiny is under the car.
Old Dec 11, 2018 | 04:18 PM
Engine: 2.8L V-6
Axle/Gears: Stock
Diagram was clear and I just got back to the issue at hand. Fabricated a new hose, connected all three ends and the car is running markedly better. Thanks for the help!
Old Dec 11, 2018 | 08:08 PM
BizJetTech's Avatar
That is a component of the cruise control as seen in view A on the diagram
yo soy el warg
Aug 13, 2011 10:46 AM
five7kid
Sep 27, 2009 08:51 AM
Jamie R
Jun 4, 2009 10:51 AM
ChillPhatCat
Carburetors
Aug 3, 2001 04:51 PM
ellinw02
Dec 28, 2000 02:42 PM
