Idle trouble.
Old Jan 7, 2019 | 03:33 PM
Michaelangelooo's Avatar
Idle trouble.
Hi, I have a 1991 Z28 Camaro that has a serious idle problem. My knowledge of cars only spans what I have had to deal with. The fuel pump had been changed, the diaphragm of the fuel pressure regulator has been changed(which was causing it to die at stop lights.), and I changed the fuel filter.
Howeve, the idle starts to flutter after about 3-5 min of running and I’m not sure what to try next. Thankful for any help!
Old Jan 7, 2019 | 09:08 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Idle trouble.
So it sounds like the problems begin when the car warms up and it goes into closed loop?
When you get a chance, unplug the O2 sensor connector the next time it's acting up and see if the problem goes away (ignore the check engine light that comes on).
dono420
Nov 1, 2004 06:58 PM
AFRO IROC Z
Jun 21, 2001 09:16 AM
rezinn
Jun 19, 2001 09:33 AM
NightHawk
Carburetors
Apr 18, 2001 01:11 PM
