Engine hard to turn after first startup
Old Jan 9, 2019 | 06:31 AM
Ralphm2425's Avatar
Hi, i have a 350 carbed engine that has been sitting for around 15 or so years. And I wanted to do a quick test run to see if it started before i bought a new alternator and water pump for it, and after a few seconds of cranking it started up perfectly (oil was also topped off). I only let it run for 6 seconds max and did this maybe four times. But when i came back a couple hours later it seemed that the engine had seized? So i took the plugs out, poured some oil in, and now it seems to turn over fine, but i havent tried starting it again. What would cause this to happen?
dwillis
Jul 10, 2013 06:55 AM
89formula350b2l
Feb 21, 2009 01:23 PM
327_TPI_77_Maro
Oct 2, 2006 12:03 PM
92GTA
Oct 28, 2004 01:36 PM
