Enrich Startup Vs. Temp & Idle Engine Speed Startup Delay
Old Oct 28, 2004 | 01:22 AM
92GTA's Avatar
Enrich Startup Vs. Temp.
What is their relationship? I mean when your engine starts, it's going by the Enrich Startup Vs. Temp. and increases the AFR whatever % you specifiy for a given temp. But how long does it hold to this AFR change? I'm assuming it's based on a time variable however the only thing I can find which would fit this would be the Idle Engine Speed Startup Delay Am I correct? My Idle Engine Speed Startup Delay is set to only 600.00 mSec.
There is also of course a Spark Advance Startup vs. Temp. which works in conjunction with the Enrich Startup Vs. Temp. but I also ask for how long do these have effect? Are they both controlled by another variable or are they both controlled by the Idle Engine Speed Startup Delay
Thanks!
Lastly real quick, why is the Enrich Power AFR Enable Min. Temp. set so high to 116* C (240* F) in all the bins I see? wouldn't you want this low enough that it actually kicks in? Isn't this one of the variables for PE kicking in?
Old Oct 28, 2004 | 07:48 AM
conv90's Avatar
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
Re: Enrich Startup Vs. Temp & Idle Engine Speed Startup Delay
Originally posted by 92GTA
Lastly real quick, why is the Enrich Power AFR Enable Min. Temp. set so high to 116* C (240* F) in all the bins I see? wouldn't you want this low enough that it actually kicks in? Isn't this one of the variables for PE kicking in? [/B]
For what I understand if the coolant is GT or EQ 116 deg°C the PE enable at TPS is replaced by the PE enable TPS When HOT.
PE enable at TPS:
70.31
60.16
50.00
50.00
50.00
If coolant gt or eq 116 the PE comes early (with less tps..)
14.84
14.84
14.84
50.00
50.00
-Beppe-
Old Oct 28, 2004 | 09:32 AM
92GTA's Avatar
Got it now, thanks!
Anyone know the answer to my other questions?
Old Oct 28, 2004 | 01:36 PM
conv90's Avatar
Car: superrammed V
Got it now, thanks!
When I have a doubt on the "logic" i open the ANHT_hack.pdf.
I search the address of the table I have to check with the search function in pdf.
SOmetimes I have the answer I search sometime not..
-Beppe-
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
