Need Advise About My Setup
Old Jan 8, 2002 | 04:56 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Im puttin a 350 in my camaro with 350 horse power what i was wondering what would be a good stall for the stall converter.My car also has 3:73 in it and a 700R-4.I was thinkin a 2400 stall for it what do you guys think...........
Old Jan 8, 2002 | 05:08 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Really depends on how big the camshaft is. This will determine
where in the power curve the torque kicks in.
The duration @.050" spec is the best/easiest indicator for this.
If it's under 230deg@.050" you'll be ok, if it's 230 or more,
you'd want a 2800 or higher stall speed. A single plane intake will like the higher stall also.
Old Jan 8, 2002 | 06:53 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Comp Cams Magnum Cams
Cam Kit
Grind: 280H
Gross Lift: .480''
RPM Range: 2000-6000
This is the cam
Old Jan 8, 2002 | 07:26 PM
GSXMEN's Avatar
I've heard that you want to pick a converter that will stall about 500 rpm below your torque peak. That way you're not lugging the motor down to a level that's not making alot of torque.
If it was me, I would put in a 2800 stall w/lockup.
Scott
Old Jan 8, 2002 | 07:39 PM
F-BIRD'88's Avatar
Cam Kit
Grind: 280H
Gross Lift: .480''
This is the cam
Good cam when used with a minimum 2800 stall
Kicks *** witha 3500 stall....
Use a Victor Jr or Performer RPM
If your stuck with a 2400 stall, it will do,, but I'd pick a smaller cam
Like this one
Grind 270H magnum
dur @ .050 224
lift .470"
rpm range 1800 -5800
Pn12-211-2
or grind 275 DEH Dual Energy
lift .462 .482
dur @.050 219 229
rpm rqange 2000 6000
works with a stock converter.
pn# 12-209-2
advertized dur 275 277
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
