Cam choice help.... Hydraulic flat tappet hyd XE 262-14 or 268-14 for TPI Vortec?
Old Jan 8, 2002 | 08:37 PM
69 Mustang's Avatar
Car: 87 Iroc Z-28
Engine: 355 Vortec Superram
Transmission: 700-R4
Trying to make a fast but streetable 355 TPI using Vortec heads and the SDC2000 TPI intake. Just wondering if anyone had either cam and how they liked it. Thanks guys
Old Jan 9, 2002 | 06:13 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i would go with the 268
make sure the vortecs have sufficent retainer to valve guide clearance.
Old Jan 9, 2002 | 06:33 PM
rhuarc30's Avatar
Definitely the 268 if those are the only 2 cams you are considering. If you've already got a roller motor though, you can easily get much more lift with a roller cam and the same duration. f you don't though the 268 is a kick *** cam, you'll have lottsa low end torque and traction isssues.
John
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
anesthes
Aug 8, 2015 09:37 PM
