350 intake question
Old Feb 28, 2019 | 04:47 PM
Thirdvert89's Avatar
350 intake question
What would cause a edelbrock 350 intake not to bolt up in the center of a 350 block
Old Feb 28, 2019 | 04:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 350 intake question
Using a older 90 degree intake on a 72 degree bolt head. You can elongate the center holes.
Old Feb 28, 2019 | 05:05 PM
Ok so I’m not a mechanic here is what I’ve found out the heads are not the original heads from the 87 block they have been changed believe the heads are correct heads so that intake which I have the center is not right due to that what in take would I need for those correct heads
Old Feb 28, 2019 | 05:08 PM
Engine: Lb9
Transmission: M20
Perimeter valve covers or center bolt ?
If they are perimeter the intake will bolt on unless it’s for 87 up heads.
Sounds like the intake is for the wrong year heads and needs to be modified to work or you need to get the right intake.
Old Feb 28, 2019 | 05:12 PM
Engine: Lb9
Transmission: M20
Old Feb 28, 2019 | 05:16 PM
Engine: Lb9
Transmission: M20
Elongate the center holes until the bolt holes line up
marcos beltran
Apr 27, 2010 03:54 PM
lasher_350
Jan 24, 2003 06:20 PM
Xenodrgn
Sep 29, 2001 03:30 PM
