LT1 valve guide heights??
Old Mar 5, 2019 | 11:30 PM
rockosocko's Avatar
Good evening guys n gals.
I'm freshening up some LT1 heads and was wondering what the "stock" guides can handle height wise? i.e.- what's the retainer distance for stock guides?
I've machined down the Vortec guides before to use the higher lift cams, but never messed with the LT1 head stuff.
Also Looks like all the guides are pretty worn also, so what's better in an aluminum head, to knurel (?) or just replace with new?
E
Old Mar 6, 2019 | 04:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: LT1 valve guide heights??
The Last set of aluminum heads I had rebuild it cost close to $400 to have the guides replaced. That’s after calling around and getting quotes from 4-600. That’s with a valve job too. I’m not a fan of knurling just a band aid fix imo. You might want to look for a already rebuilt heads that have been ported too.
Old Mar 11, 2019 | 12:09 PM
rockosocko's Avatar
Thank You 'Tuned'.
My main issue is that I'm parts rich and cash poor for now.. (like most) I've got a couple good machining guys that I've used for the past 30+yrs, but like I've said, I've never messed with the Aluminum heads that Chevy offers, Mostly Honda's..
Old Mar 12, 2019 | 11:40 AM
Engine: Lb9
Transmission: M20
Id be curious on what they charge in your area.
Hope it’s not a arm and leg and that you can avoid knerling
Old Mar 15, 2019 | 11:55 AM
rockosocko's Avatar
My 'guy' is pretty busy so asked another that I've used before..
16 Guides $160
Valve job $150
Clean/media blast heads $60
And to deck my 283 .045 would be another $160
(I could probably get better pricing, but would have to wait a bit. ..and have CASH!)
This 283 was purchased a while back with .060 over forged pistons that measured out to .045 in the hole, and wanted to get up to "0" when I freshen it up with the LT1 heads..
The self ported '062's that I had on before, as you know only have around 64cc chambers and gave me around 8.3:1 with shim Head Gaskets. That's why I'm wanting to use the LT1 heads, To raise the compression a bunch to satisfy the ex268 cam, and should put me at 10.3:1
..BUT! I also have a baby LT1 from a Caprice (4.3L) that I just read on a forum that the chambers are even smaller, so I might use those and won't have to spend the extra $$$ to deck it.
I guess I should've titled this thread as "What's the max lift stock LT1 guides/seals can take without machining"
After I posted, it didn't sound right. But it is what it is.
Thanks guys.
E
turbokinetic
Oct 28, 2015 09:16 PM
neagan
May 19, 2006 02:15 PM
Batass
Mar 23, 2006 05:22 PM
blck80z28
Apr 29, 2002 08:48 PM
