Vortec valve question.
Old Mar 23, 2019 | 12:40 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
So i have all new components for my vortec head, my question is, can i just replace the valves or will i need to get grinding compound to renew the seat or will i be ok to just replace the valves and move on to the next.
Old Mar 23, 2019 | 03:41 PM
GeneralDisorder's Avatar
Re: Vortec valve question.
Well it depends on the condition but ideally you should have a machine shop do a 3 or 5 angle grind on them. Lapping them in is generally a poor substitute for a real valve grind and won't hold up over time.
GD
Old Mar 23, 2019 | 03:55 PM
happyhapka's Avatar
The condition of the heads are good but was wondering if i could just slap new valves in it.
Old Mar 23, 2019 | 04:11 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Lapping is not a substitute for cutting valves seats. Freshen up a valve & seat already ground correctly yes lapping will restore or improve a valve and seat grind. Now to make things more confusing the newer valve cutting machines are so accurate many shops will install newly cut valves in any order and overlook small leakage. But a good cylinder head rebuild will include leak checking the valves.
1985IrocZ
Apr 19, 2009 12:01 PM
89formula#1
Nov 29, 2003 08:05 PM
2ponchos
Apr 9, 2002 05:22 PM
Scott C
Jan 6, 2001 03:16 PM
