piston to valve clearance
Old Jan 9, 2002 | 06:17 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I am running a ZZ4 short block with trick flow heads. Now I only have a .015 inch head gasket and was gonna run a cam with maximum .503 lift. I think it will be ok, but you guys think my piston to valve clearance is fine?
Old Jan 9, 2002 | 09:59 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
duration normally plays a larger role than lift
I think car craft did a test on the ZZ4 motor with Comp cam solid roller. It had like 242 degrees duration at .050" and .560 lift... i think it was still using the stock ZZ4 pistons but valve clearance was near the lower limit.
Old Jan 9, 2002 | 12:00 PM
a73camaro's Avatar
Best to measure it. Do this when your degreeing in your cam.
Old Jan 9, 2002 | 05:50 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Best to measure for piece of mind, but you are going to be fine, IMO.
Old Jan 9, 2002 | 06:55 PM
ede's Avatar
ede
be best to measure it, i do it without the gasket in place. from what i've saw you won't have a problem with flat tops untill you get over .600 lift, maybe even closer to .650.
db057
Apr 28, 2019 07:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
