Steering wheel lock plate dust cover
Old Mar 29, 2019 | 11:35 AM
johnw999's Avatar
How do I remove the dust cover?
Old Mar 29, 2019 | 12:47 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Steering wheel lock plate dust cover
Been a while, but isn't there a small snap ring in the center that needs to be removed?
Old Mar 29, 2019 | 12:51 PM
Read this thread first. It should answer all of your questions. It is a very good guide.
https://www.thirdgen.org/forums/susp...-steering.html
Old Mar 29, 2019 | 09:43 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That slot is a clip around the outside. Stick a flat blade screw driver in there and carefully pry out while pulling toward you. There should be a few more clips around the outside like that
Old Mar 29, 2019 | 09:44 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The part he is asking about isn't there, lol
Old Mar 29, 2019 | 10:19 PM
You're right. I was thinking he was referring to the lock plate piece that sits behind it.
Old Mar 29, 2019 | 10:33 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I hadn't actually looked at the link until after I posted. It's just funny that it starts right after removing the dust cover
Old Mar 30, 2019 | 10:58 AM
johnw999's Avatar
A different website covered the GM dust cover. It didn't come off as advertised, and yes, I broke it. I had to source a replacement part from ebay. The dust cover has been discontinued. I also had to order a pair of special pliers to remove the snap ring. It ain't coming off without a struggle either. What a pain this is becoming.
Old Mar 30, 2019 | 12:51 PM
That snap ring can be difficult if you don't have a pair of snap ring pliers. If you do, then its a snap. Take your time. The steering column can be a pain, but it is doable.
Old Apr 4, 2019 | 02:40 PM
johnw999's Avatar
Ah, the snap ring. I ordered 2 special pliers. Both didn’t work. I haven’t been here in a looong time. I’m at that point, though. I’m at the “who the <censored> designed this <censored>Ing thing and what the <censored> were you thinking!!!!” point. Grrrrr!!!!!
Old Apr 4, 2019 | 03:20 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
If you are at that point, put the pliers down - slowly - back away..... Steering columns can be very frustrating, but they are finicky and the parts can be fragile. That's when it gets expensive. Figure out exactly what you're gonna do first, THEN proceed slowly. There are guys who have done it before, and once you do it a time or two it really is straight forward. Find one of those guys..... It will be worth it in the long run, especially if you can watch over a shoulder.
Old Apr 4, 2019 | 04:14 PM
johnw999's Avatar
You are so right. I ordered snap ring pliers earlier this week. It arrived today, but it was too big to fit in the ring gap. Hence, my rant. An hour later, I got an idea. What if I used a dremel to grind down pliers meant for retaining rings (the ones with holes for grasping)? So I did, and I finally had what I needed. A pair of tweezers that open when the handles are pushed together. It shouldn’t have come to this. But, it worked. The evil ring is off. I shall proceed tomorrow.
The pliers that were too big:
The retaining ring pliers
The retaining ring pliers with different inserts that I shaved with a dremel:
Stupid snap ring!!
Old Apr 4, 2019 | 04:22 PM
The snap ring pliers I had came with different sets of pins that were removable. That was a big help. Either way, congrats. You too your time and made it happen without breaking anything.
Old Apr 4, 2019 | 07:08 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
There's an outfit in so cal, can't remember name but u can buy a new snap ring for under$10 bucks
Old Apr 4, 2019 | 08:18 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The problem is that is NOT a snap ring. It is some sort of retaining ring and the ends are not amenable to using a tool to try to open it to remove. I have always had better lock with a couple picks to get behind it, then a small screw driver underneath it to start it up the shaft.
romcjr
Interior Parts Wanted
May 29, 2012 12:58 PM
Abubaca
Jun 7, 2010 03:33 PM
Ant
May 30, 2006 11:12 PM
MrDude_1
Jul 8, 2004 04:48 AM
foney_email
Sep 11, 2002 04:26 PM
