dust! dust! everywhere underhood! ack!
Old Jul 7, 2004 | 11:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
lol
so i have my engine out, and i wanted to clean out the engine compartment before i drop the new sucker in there.
simple green is some good stuff, so i made a nice strong mix of it (roughly 70/30) and sprayed it everywhere underhood. i made sure to get in in the hard to reach corners and behind stuff where dust collected...
i sprayed it all off with a garden hose.... looked great.. until it dried.
all of the grease and grime were gone, but the dust was still clinging there....
i cant scrub everywhere where i want it cleaned, what can i do to get this dust out?? to make it worse, everytime it gets wet, it disappears.
tips and hints would be great.
Old Jul 7, 2004 | 12:18 PM
Kandied91z's Avatar
lol...be thankful you don't have an open element hood like ss or ws6 style.
Old Jul 7, 2004 | 12:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you going to just stand there and laugh, or are you going to tell me how you clean your car?
Old Jul 7, 2004 | 01:26 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
well..
it takes me like 9 hours to fully clean my iroc for a show...
as for the engine compartment...
you will never EVER get it 100% clean..dust is the devil it finds a way to get there and stay there..trust me i wish i could not have dust...you just have to continue to clean it over and over..its a tedious job..but if you want a pefect car..thats how you do it..
iroc2nv
ps..only thing i can say..dont use anything that attracts the dust more...such as tire shine or anything glossy
Old Jul 7, 2004 | 01:32 PM
89IROCCVRT's Avatar
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
i had the same problem as you man, cept i was getting my iroc and my 81 ready for the 4th of july parade, and car show and everytime i washed/waxed it, it would look clean as can be...let it sit for about 3 minutes and i could see pollen galore everywhere on it....the only thing i could do was keep wiping it off with a rag (dry or slightly damp) over n over n over again...it takes most of it off but it still left enough to notice it...good thing no one was actually close to my BLACK iroc during the parade...that yellow pollen sure does show up when you're close up to it (it wasn't too too bad on my orange/ kameleon striped 81 tho)
Old Jul 7, 2004 | 02:12 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
hey never tried this but it struck me reading your post what about one of those swifter duster things it is statically charged to attract the dust.
Old Jul 7, 2004 | 02:24 PM
Daytona T/A's Avatar
Car: 1983 25th Anniversary Daytona 500 Pace Car Trans Am
Engine: 5.0L 305 Crossfire-Injected V8
Transmission: 4 spd. auto
well if it's just "dust" I don't understand why you can't just rinse it off. I also don't understand how you got all the grease and grime off but not dust... or is this like years of caked-on nasty dirty gross sh**...
Old Jul 7, 2004 | 03:09 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
try some dish wash mixture, you sure its not just bad paint.
Old Jul 7, 2004 | 03:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the greasey stuff was easy.... the only grease underhood was by the power steering box.
im talking about the fine layer of silt, grayish dust that a car picks up after 130+k...
it comes off.... most of it is off where i can rub it... but between and behind stuff, i can see it but cant scrub at it...
Old Jul 7, 2004 | 03:23 PM
FLYNLOW92rs's Avatar
Toothbrush.......
Old Jul 7, 2004 | 04:34 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
If you can, although since you got the engine out, try to find a pressure washer or tow it to a car wash and just pressure wash the **** out of it, should help get the bulk of it off. If not, do like FlynLow said get a tooth brush, make an elbow, extend it, to do whatever ya can to get to what ya can't get to if that makes any sense :P.
BTW, watcha throwing in it?
Old Jul 7, 2004 | 06:14 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
dust? ae you sure its not the clear coat that has hazed over from to strong a cleaner burining it? take a spot and rub it with some compound or a cleaning wax and see what it does. i sounds like oxidation.
Jeff
Old Jul 7, 2004 | 11:58 PM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
Why not use a blow off tool to get the dust out? It works good for a lot of things like that.
Old Jul 8, 2004 | 01:21 AM
Kandied91z's Avatar
wasn't laughing at you, basically knowing what you go through and telling you how luck you are to not have a hood like my own. well if it's actual dust it's impossible to keep it off the car, you'll need to clean it once in awhile. if it's long term like i'm thinking then it sounds like oxidation. that or dirt that has been burnt into areas from heat which happens.
i use basic polish products and a 50/50 simple green/water mix and i've never had any problems.
the new ss hood being open really keeps my bay dirty so i'm working on sealing it up but beyond that it shouldn't get too bad.
Old Jul 8, 2004 | 04:48 AM
CrazyHawaiian's Avatar
Car: too many ...
When I cleaned up the engine bay of my 89 RS for painting (8 months ago?) I used a de-greaser solution from a local company:
Auto Chem Systems
(808) 216-4525
94-150 Leoleo Street Suite 6B
Waipahu, HI. 96797
I'm sure you could find the same type of product locally. Anyway, finished it off with a pressure washer/sprayer and looked almost new. No grease, no dust, no problems. Sanded it good, and sprayed it black. Looks great!! And now that I have the tranny and TQ arm out of my IROC I'm thinking about doing the same thing under the chassis (minus the sanding and painting lol). But wouldn't recommend this process unless the engine bay was empty ... I'm sure the rubber hoses would be damaged by both the de-greaser solution and the pressure washer/sprayer.
Street Lethal
Apr 30, 2019 12:14 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Denricci22
Sep 18, 2015 09:02 AM
FormulasOnly
Sep 10, 2015 09:07 PM
