New high pressure fuel pump for aftermarket EFI not working
Car: 88 Camaro RS
Engine: 305 w/ carb
I decided to buy the whole summit 500 EFI setup for my car, and bought a new high pressure in-tank fuel pump to keep up with the injectors. I have everything set up, but the new fuel pump will not turn on.
- The pump gets power to it from the plug
- It works when hotwired outside of the car
- It has continuity when outside, but not when inside the tank
- The pump won't work even when hotwired inside the tank
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: New high pressure fuel pump for aftermarket EFI not working
Sounds like you diagnosed it already. probably a CHEAP junk Chinese pump.
JimmyG-91Z
Jul 17, 2003 04:21 PM
Jstcrzyengh
Apr 11, 2003 04:33 PM
BuckeyeROC
Aug 12, 2001 12:05 PM
RSR
Mar 12, 2001 06:13 PM
