Cam selection charts by IVC point.
Old Apr 21, 2019 | 08:31 PM
NoEmissions84TA's Avatar
Do any charts like this exist for the current camshaft offerings? I did the calculations and made my own charts for the really old camshafts. It took days making all of those calculations.
I am helping a buddy with an old school 383 SBC and a flat tappet with an IVC point of 60 degrees would yield a DCR of 8.17 at sea level.
An ISKY 264 Mega is one such choice.
Old Apr 21, 2019 | 10:03 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Cam selection charts by IVC point.
What do you mean by "Current Offerings". Are you referring to OEM stock camshafts? Probably not unless someone measured them.
As for any aftermarket cam? That can be provided by the MFG. Most times just by looking up the grind on their website.
Example, the CC-306 that people love to shove in LT1s. But really you can look up any CompCam specs this way. Same for Lunati and others. If its not listed, call the MFG and if they can't provide it, they don't deserve your money.
http://www.compcams.com/Company/CC/c...csid=1103&sb=2
The IVC, IVO, EVC, EVO are all listed, along with gross and at .050" lift durations. LSA, LCA...etc.
Old Apr 21, 2019 | 10:26 PM
Thanks. I was talking about current offerings from the major brands; Crane, Crower, Lunati, CompCams, ISKY, etc.
Here are my charts for the streetable old flat tappet camshafts.
Old Apr 21, 2019 | 10:34 PM
I just looked up the cam in my GTA. Lunati Voodoo, the IVC...etc is not listed on the website. Though all the other specs are.
https://www.lunatipower.com/Product....d=2012&gid=289
However, I do remember calling and asking for the event timing and they gave me the #'s over the phone.
Basically, the cam MFG should be able to give these #'s to you. If not, they are being shady and you should not do business with them.
When you buy a cam, it should come with a sheet of paper referred to as the Cam Card. This has all the valve events, lift, duration, lobe sep, lobe center...etc. Everything.
Old Apr 21, 2019 | 11:15 PM
http://wallaceracing.com/cam-deg-calc.php
OK, for your cam:
IVC is the number you need to calculate your DCR.
Old Apr 22, 2019 | 08:30 AM
OK, for your cam:
Almost right, IVC is actually 68°. So its good enough for ball parking things.
camarosource
Jan 6, 2003 08:07 PM
BOTTLEDZ28
Oct 7, 2002 08:41 PM
d4nk
Aug 19, 2002 09:42 PM
Marin
Jun 22, 2002 04:07 PM
prscarf
Mar 31, 2002 02:28 AM
