missfiring 305
Old Jan 9, 2002 | 04:10 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
missfiring 305
ok, ive been wondering this for a long time : why does every 305 motor in a 3rd gen have a missfire? Ive owned (3) 3rd gen T/As, and just recently purchased a 84 Z28, and all of them had a miss. Bad ones too. Besides cap/rotor/plugs/wires, what else could cause this to happen in this motor? Ive also owned (2) 350s (both tuned port), and neither of them had this problem. Just in case it matters, 2 of the 305s were TPIs, one was the Crossfire motor, and the Z28 has the LG4. Any help is appreciated.
Old Jan 9, 2002 | 04:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Considering that the 305 and 350 are identical in practically every way except bore diameter, I'd say you are a victim of bad luck.
Besides tune-up parts, things that can cause a cylinder not to run are a blown head gasket, or damaged valve train parts (bent push rod, rolled cam lobe, bad rocker, etc.). These things can happen equally easily to a 305 or 350.
Old Jan 9, 2002 | 05:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Besides the mechanical things RB listed, could be pickup coil, ignition module, reluctor..possibly the coil as well, bad injector.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
