No injector pulse after car warms up.
Old May 11, 2019 | 07:33 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
1991 Z28 LB9. All original, car starts up just fine when cold.
But once running for a short while the car just quits. Have 42lbs of fuel pressure. Have spark to the plugs. However, the injector pulse quits out of nowhere. Wont start back up for a few hours until it cools down.
What can cause the ecm to be told to stop firing injectors?
Thanks.
Old May 11, 2019 | 07:54 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: No injector pulse after car warms up.
My four most likely suspects , in no particular order , would be ;
Bad injectors that have OK resistance when cold , but get lower resistance when hot , dragging down the injector pulse . An ohm check of the injectors both cold and warm will tell if this is the case .
Bad ICM getting hot & not sending the distributor reference pulse to the ECM (even though it's still making spark the reference pulse still could be going MIA) .
Bad ECM .
Bad electrical connection to or from the ECM that gets hot and goes open circuit .
Old May 11, 2019 | 09:21 PM
GeneralDisorder's Avatar
My guess would be the ICM.
GD
gta power
Aug 8, 2013 05:12 PM
90caddy
Aug 22, 2012 09:29 PM
kane91z
Feb 22, 2001 10:49 AM
gsmann
Nov 14, 2000 02:39 PM
rondubbs
Oct 29, 2000 12:17 PM
