Piston Question
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Piston Question
Other than compression, flat tops may induce more turbulence as it approaches tdc during the compression stroke. This basically is like a big quench pad, this helps mix the air fuel and get a quicker faster burn. May be more desirable for power production/ efficiency vs a dish but not sure what difference it may be.
Re: Piston Question
Basically they improve the quench if you have appropriately shaped chambers (such as Vortec style) with a large flat area that the piston can squeeze against. This better atomizes the fuel and generally helps prevent detonation. If you have bathtub chambers then there's not nearly as much benefit. Also all the force of the combustion is directed straight down vs some of the forces near the edge of the piston being directed at oblique angles with a dish. This is somewhat less efficient. Dished pistons are generally considered either smog equipment or for forced induction applications where a reduced compression ratio can't easily be accomplished by other means.
GD
GD
TheMechanic74
May 30, 2010 10:28 AM
91NiteRida'
Feb 6, 2004 05:35 PM
