1991 Z28 Fuel pump only 10 PSI
Old Jun 13, 2019 | 07:00 PM
Kenny Quintero's Avatar
Hello All! I been trying to track the problem I been having the engine has no power, and tries to cut off when i give it gas. After replacing the coil, distributor module, TPI sensor, and fuel filter still have the same annoying issue. I decided to rent a fuel pressure diagnostic tool from Autozone and noticed only having likes 10 psi or less reading! I'm quite sure this has to be my issue all along... I have the TPI 305 engine. Any advice taking on this job I greatly appreciated. What is a good value pump assembly I can use? I seen all kinds on ebay I'm looking for any advice on that. I do all of my mechanic work my self, how dificult is to drop that tank, what things to look for and what should I be replacing in the process?
THX! for the input.
Old Jun 13, 2019 | 07:24 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 Z28 Fuel pump only 10 PSI
You need to stick to one thread
https://www.thirdgen.org/forums/tech...1-z28-tpi.html
ep241 delco
Old Jun 14, 2019 | 05:10 PM
GeneralDisorder's Avatar
All due respect to the old 80's Delco EP241, but there are MUCH better options out there now. Silent, high volume, and inexpensive. I recommend the AEM 50-1200
GD
Old Jun 15, 2019 | 08:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I've been using racetronix stuff for years. Very good luck with those so far.
LostX
Dec 23, 2012 06:49 PM
89mulletbird
Aug 6, 2012 04:41 PM
88_Import_Slaye
Feb 5, 2006 10:52 PM
Kingtal0n
Jul 12, 2004 05:21 PM
