Do I need to remove the intake manifold to replace the stock cam?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I'd rather not of course. Hoping I can spin the stock cam around to lift the lifters but the new cam I am putting in is taller. Or maybe someway pull the rollers up. But if I gotta, I gotta.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Do I need to remove the intake manifold to replace the stock cam?
The intake needs to be removed.
On the roller cam engines the spider and dog bones that keep the roller lifters from spinning will thwart your attempts to pull the lifters up out of the way of the cam journals.
GD
GD
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
If you don't remove the manifold, how do you plan to extract the lifters from the bores in order to pull the old cam and replace it? And then put them back into the bores when you are done?
Pull the manifold.
Pull the manifold.
GD
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Replacing cam and lifters without pulling the manifold is easy on a Crossfire injection engine(flat tappet)-just pull up the lifters with magnet tool,drag them back and out the dizzy hole
I think stock carb manifolds don't have enough clearance above the valley to do this,but TPI or aftermarket carb might.Can't be done with roller lifters...
I think stock carb manifolds don't have enough clearance above the valley to do this,but TPI or aftermarket carb might.Can't be done with roller lifters... Joined: Oct 2001
Engine: 4++,350 & 305 CIs
You can do it with a bunch of those cheapy extendable parts store magnets but you still have to pull the distributor. Way more work than just pulling intake. Good time to clean and port it too.
