Oil pooling up under throttle linkage?
Old Jun 26, 2019 | 11:20 AM
DoctorStoopid's Avatar
Car: 1987 Trans Am
Engine: LG4 305
I've had this problem for as long as I've owned the car (since Nov, 2018) and thought rebuilding the carb and replacing the gaskets would help, but it doesn't seem to have.
After driving the car (but not idling) for any period of time, if I pop the hood and check under the throttle on top of the intake manifold, I get a nice little puddle of fresh oil in the area under the throttle linkage, right near cylinder 3's intake runner. I have no idea where this could be coming from as the carb is fresh, the gaskets are new, and everything is tightened down. No vac leaks as far as I can tell. Where would this be coming from? Everything is stock. Where should I begin looking? Thanks!
Old Jun 26, 2019 | 12:00 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Oil pooling up under throttle linkage?
Probably oil splashing around in the valley and migrating up the threads of a nearby intake bolt. Remove the bolt, put a dab of gasket sealer around the threads, and re-torque.
Old Jun 26, 2019 | 12:25 PM
Car: 1987 Trans Am
Engine: LG4 305
That's a new one! I know the intake has a specific order in which torquing is required. Am I cool to do this with just the bolt in question or is that going to compromise the seal on the whole intake requiring me to remove and retorque everything?
Old Jun 26, 2019 | 01:02 PM
It's coming up the intake bolt threads. The center 2 bolts go right into the crankcase.
Take them out one at a time; clean the bolts up good, chase the threads in the head, clean with spray carb cleaner; seal with thread sealer; torque to about 25-30 ft-lbs.
Old Jun 26, 2019 | 02:50 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Won't all the small filings from chasing head threads go into the crankcase? Just wondering.
Old Jun 26, 2019 | 04:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Chasing the threads is different from taping. It just removes the crud in the hole.
Old Jun 26, 2019 | 04:18 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
If it's just one or two bolts, it's not a problem. If two are involved, just do one at a time.
Old Jun 26, 2019 | 09:00 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I know that Brian....and that crud goes to the crankcase. Just thinking ahead. Carrry on.
Old Jun 26, 2019 | 09:16 PM
Engine: Lb9
Transmission: M20
Your right might not be the best of ideas, forcing crud that are in the threads into the crankcase.
A thread chaser might not have much reach to clean many of the threads either.
I would just clean the bolt threads and use liquid Teflon on the threads and retorque.
LoganK
Oct 21, 2013 10:08 PM
Tyler Mac
Jan 21, 2011 07:05 AM
Stealthy-One
Oct 16, 2006 02:54 PM
PioneerCrazed
Jul 28, 2003 07:08 PM
Jim85IROC
Jan 23, 2002 06:47 PM
