Not Good... Water pooling from rear of engine....
Old Jul 28, 2003 | 11:34 AM
PioneerCrazed's Avatar
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
Just recently when I park my car after a drive, water pools under the car, it seems to be coming out of the cover between the engine and tranny.... Only sometimes does this happen, anybody had similar issues? Could it be the freeze plugs? The water seems to be fairly cool, not 200*, so I'm stumped, but it is definatley leaking coolant like crazy...
BTW its not the AC Condensation
Old Jul 28, 2003 | 02:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if its actually leaking from the back of the engine i would havta say a leaky freeze plug or a crack in the block but it could always be runnin down from somewhere else too....
Old Jul 28, 2003 | 03:05 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
might want to check rear intake manifold gasket. it may be leaking from there.
Old Jul 28, 2003 | 03:39 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, why not try some stop leak. You have nothing to loose.
Auggie
Old Jul 28, 2003 | 03:40 PM
gmsmallblockguy's Avatar
coolant or water?
Comming out cool to the touch right after driving?
Old Jul 28, 2003 | 05:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Comes out mostly on real hot days? When you're trying to stay cool yourself?
Air conditioner condensate from the evaporator housing.....
Old Jul 28, 2003 | 05:42 PM
RJR99SS's Avatar
yeah on hot days you will notice water dripping from your engine bay. Its usually the water that condensed on the a/c lines.
I had a riviera that would drip water from the frame pretty regularly, i never figured out exactly what cause it. But it was certainly just water, not coolant or oil.
Old Jul 28, 2003 | 06:09 PM
jms's Avatar
jms
I don't know if you have an LG4 but I have worked on a few that had a leak on the passenger side rear of the intake manifold that allowed coolant to run down the back of the block.
The area corroded (from the inside) where the head water passage meets the intake manifold there.
I even tore down one that had corroded within 1/32 of an inch of allowing coolant into the lifter galley!!! That could have been interesting.
After one of the more recent tear-downs, I was unable to find a suitable factory aluminum intake that was not already corroded so I installed a Edelbrock intake. Not for the performance mind you
jms
Old Jul 28, 2003 | 07:08 PM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
Alright thanks guys, I'm going to check some of this stuff out tomorrow and hopefully make some progress, hopefully not a cracked block (fingers crossed), but the water is cool to the touch...
I don't think that its the A/C because that drips elsewhere, but possibly since it;s cool
Later
eightsixseven
Dec 16, 2024 01:50 PM
lakeffect2
Aug 23, 2015 08:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
