Can I put ya 1.6 rocker arms on my stock L98?
Old Jan 10, 2002 | 09:38 AM
87transam5.7tpi's Avatar
I heard you can gain about 15 - 20 hp if you add 1.6 rocker arm on a stock motor. my questino is does anybody knw what kind of lift this will give me with a stock L98 with .404 (int.) .415(ext.) lift? I'm pretty sure that the stock rocker arms were 1.5 right? any help would be great. I also know that a cam would give me tho most power, but rocker arms are only around $150 instead of 300+ and it be easier to install also. thank you
Old Jan 10, 2002 | 11:16 AM
craiger's Avatar
Yes you can put the 1.6 rocker on a stock L98. I had a stock l98 with a supercharger on and i ran a 13.2 with my setup. I put a set of slp runners on, airfoil, and a set of Crane Magnum roller rockers on and ran a 12.8. Consequenlty, my new engine has AFR heads and my cam maxed out the springs on my AFR heads so I can not use my 1.6 rr's So now i am selling my Magnum roller rockers for 125 plus shipping. I only have 2500 miles on the rocker's and I purchased them last spring. I think they were onthe car for 5-6mo. They arelike new if you want them.
Old Jan 10, 2002 | 01:16 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
1.5:1 rocker ratio lift:
.404" Intake, .415" Exhaust
1.6:1 rocker ratio lift:
.430" Intake, .443" Exhaust
Simple math.........
Old Jan 10, 2002 | 01:24 PM
craiger's Avatar
I Think stock springs will handle up to 500 lift but i would not go over .480.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
happyhapka
Aug 15, 2015 04:42 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
