car runs better with vacuum hose disconnected from egr?
Old 07-14-2019, 06:47 PM
myzticc66's Avatar
Car: 1987 Chevy Iroc Z
Transmission: 700 R4
So, I was having a weird cooling problem with my car the other day. It runs about 220 on the highway which to me seems a bit high. After about 40 minutes and this happens all the time it slowly creeps up to around 230 maybe 235? Last year I redid the intake manifold, new radiator and a new thermostat and flushed the system. So I was about 3 miles from home and the temp went past 240. I got into the garage and coolant was spraying from the top of the coolant reservoir which was actually boiling. I let it sit overnight cleaned everything with hose water let it dry and started it up. there are no leaks anywhere and I find nothing wrong with the water pump. I just don't know what the hell is making it so hot? So anyhow while I was going through checking for hoses and leaks I found the vacuum hose from the egr disconnected. Of course I reconnected it. Took the car out and it just runs like trash. every time I come to a stop it idles too low and dies? The heating problem got a little better the cars running about 230 now and not overheating but with the low idle and stalling at stops its pretty much undriveable. So I am going to pull the vacuum line back off the egr? anyone ever hear of this? So 2 problems running too hot and the egr. Anyhow thanks!
Old 07-18-2019, 08:46 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Re: car runs better with vacuum hose disconnected from egr?
EGR should be shut off at idle. Sounds like a problem with the EGR solenoid.
Old 07-18-2019, 08:54 PM
myzticc66's Avatar
Thank you, I will check that out this weekend.
SatisTraction
10-19-2007 11:04 PM
zedder 1 9 9 0
06-12-2001 12:06 AM
voltran
12-05-2000 05:34 PM
Quick Reply: car runs better with vacuum hose disconnected from egr?
