loosing lots of coolant??
Old Jan 10, 2002 | 03:39 PM
Vomex's Avatar
Just wondering what may be causing the loss of coolant. There are no visible signs of a leak or any corrosion near the radiator. I dont know where all the coolant is going. It was full a month ago and yesterday i had to put in about 2 liters. Any one have any ideas
Old Jan 10, 2002 | 03:59 PM
Z28DJP1987's Avatar
Do a compression check, sounds like a Head Gasket problem. You do not lose coolant with out a reason, good luck.
Old Jan 10, 2002 | 04:05 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Same thing was happening to my friend in his '88 Vette a few weeks ago. Is coolant getting into the oil or vice versa? Check your oil and if it is milky looking then you have coolant in the oil. Usually this is a head gasket problem but for my friend it turned out to be his oil cooler. The piece that goes in between the block and oil filter was leaking. May want to check that before you pull a head off.
Old Jan 10, 2002 | 04:59 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Does your car interior smell like coolant?
If so check the passenger side floor, you could have a leaky heater core.
F-body driver
Mar 6, 2023 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
89 formula TPI
Oct 6, 2015 08:40 PM
TheTraut88
Sep 11, 2015 05:16 AM
middian
Sep 5, 2015 01:42 AM
