Truck Vortec Heads
Car: 1987 IROC z
Transmission: 700R
Axle/Gears: POSI 3:27s
Truck Vortec Heads
So I had another thread going about a Crate Engine but decided to wait for next Spring.
But for now, I can get a set of Vortec Heads off a 1997 Truck Engine for $100.
Pretty sure there’s well over 200k KMS on the Engine.
Would I need to do any work to these Heads and can they just bolt on to my 87 L98 TPI ENGINE with the Scoggin Dickies Intake?
Re: Truck Vortec Heads
Probably should rebuild them
FYI - ALL Vortec heads are from truck engines. The 5.7 Vortec was not used in cars.
GD
GD
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Make sure you check for cracks. The center bolt hole and the two middle exhaust ports are most know I think. Don't quote me on that though. Also depending on what cam you are running. The max lift varies from whoever you talk to. I have read everything from .420 to .480
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I would rebuild them and have them checked for cracks. Make sure they are 350 heads not 305 heads
Is this a budget build or do you plan on it lasting long? Cause I got kinda the same thing, some 200k vortecs and I'm just gonna mod em myself and use em but I don't expect them to last forever and they aren't going on a new/fresh engine. I plan to check them for cracks myself and expect to find some small ones, I'll burn that bridge when I get there LOL At the least you'll prob need to lap them and their are tons of diff opinions on lapping(again see 1st sentence). Anyways if you wanna check out my build to see how it turns out, check out my youtube channel, I'm documenting my experience. I'm sure it will **** of tons of internet experts LOL
One of my vids Pull & tap studs
AJ_92RS
Aug 30, 2019 12:32 AM
1bad406
Oct 15, 2012 11:11 AM
Bryant
Dec 11, 2000 01:28 PM
