Crazy Idle or no start after battery disconnect
Old Aug 1, 2019 | 03:32 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
All ran fine prior to disconnecting the battery, replaced a relay and wired in a new relay connector for my secondary fan. Reconnected battery and now either won't turn over or if it does, the idle is all over the place and then dies. I literally did nothing else to the stupid thing and logging with TunerPro gives no error codes. Anyone have any guesses?
Old Aug 1, 2019 | 03:48 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Crazy Idle or no start after battery disconnect
My first step would be verifying you have good ground.
Old Aug 1, 2019 | 03:50 PM
Car: '89 Iroc
Engine: 383 TPI
Thanks, planned to check that tonight on the new connector I put in. Has to be something with what I touched and that was it.
Old Aug 3, 2019 | 03:41 PM
Car: '89 Iroc
Engine: 383 TPI
So I’ve removed the new harness all together and put the stupid fan wiring back how it was and am still in the same boat. Anything else obvious to check?
Blaze of Glory
Jun 3, 2008 01:54 PM
eddie jr
Jun 23, 2004 09:33 PM
RoadRocket L98
Apr 10, 2001 02:14 PM
