Zz4?
Old Jan 11, 2002 | 01:42 PM
Team FTS's Avatar
Zz4?
Difference between ZZ4 and regular SBC I currently have a 91 TPI 305 and was thinkin about gettin the ZZ4 what are the differences between the engine and the 87 and later SBC?
Old Jan 11, 2002 | 03:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Both have roller cam and one-piece rear main seal.
The ZZ4 has hypereutectic pistons and PM rods, regular has cast pistons & rods.
ZZ4 also has a better oil pump and a pan baffle.
The ZZ4 heads are aluminum with 58cc chambers and no exhaust cross-over passage (like the Vette L98).
Old Jan 11, 2002 | 06:42 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
You will need to have the two center bolt holes on the 91 305 TPI intake milled to fit the olderstyle heads of the ZZ4. Or you could just pony up and get an aftermarket intake. The Edelbrock comes milled for both type heads. Everything else bolts up.
My ZZ4TPI combo just passed 40K miles.
Old Jan 11, 2002 | 07:46 PM
Team FTS's Avatar
if I only use the ZZ4 block would I should be able to use the centerbolt valvecover style heads then? I am looking into it as a foundation for my project cause I want to use AFR heads a Mini-Ram, or LT1 manifold and I want to have a good foundation
Old Jan 12, 2002 | 05:36 AM
Rob P's Avatar
Engine: ZZ4TPI
I'd imagine any SB head for a SBC I would work on the ZZ4 block.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
