How to cut a bolt?
Old Jan 11, 2002 | 03:18 PM
88firebird305's Avatar
How to cut a bolt?
I bought new bolts for my water pump pulley, from gm right part number, but they are to long. They rub the shaft, the strange thing is the distance it is to long is flat on the screw there are no threads. Is this done for a reason, or do they know there to long and your going to have to cut them so the leave thread off there?
So should I just hacksaw the extra lenght off, or should I go out and try to find the same bolt but shorter?
Old Jan 11, 2002 | 03:24 PM
Iroc_Z28's Avatar
bolts
you can cut them if you want but autozone or most any of your local auto parts places will have the water pump fan bolt studs in the size you will need for a cpl of dollars
Old Jan 11, 2002 | 03:29 PM
I have an 88 with the serpintine system, so there not the studs, but just 4 bolts that bot the pulley to the water pump.
But the same I guess would apply to autopart stores.
Terrell351
Jun 13, 2021 01:13 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
LittleFranks
Aug 20, 2015 03:55 PM
