battery connections
Old Aug 28, 2019 | 01:50 PM
Matthew David's Avatar
battery connections
I drive a 2003 Mitsubishi Eclipse GS and sometimes when i compress the clutch and turn the key to start it. all the lights and everything in my car shut off and it doesnt turn over at all like the battery has been disconnected. could it be a bad battery or a bad connection?
Old Aug 28, 2019 | 01:55 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: battery connections
Hi Matthew,
This is a Camaro and Firebird site but, as long as you are here, it sounds like your battery has gone bad. Once you turn the key, the starter motor is connected to the battery so that it can spin the engine to get it started. It is a much, much bigger electric load on the battery than anything else in the car. If the battery is weak, the starter motor will drag the battery (and car) voltage down to near zero. That's why when you turn the key everything shuts off.
Old Aug 28, 2019 | 01:57 PM
thing is, nothing turns over its a instant like shut off of everything electrical. engine doesnt even starrt
Old Aug 28, 2019 | 01:58 PM
i can get out reposition the ground connection and everything comes on but then its just repeats it
Old Aug 28, 2019 | 02:35 PM
GeneralDisorder's Avatar
The terminal connections are loose. Replace the cable terminals and correctly tighten them. You should not be able to reposition the terminal. This means it's loose.
GD
soldierone
Mar 29, 2013 12:56 AM
SSZ2891
May 12, 2011 10:50 AM
92purplehaze
Mar 30, 2007 12:42 PM
5.7L89IROC-Z350
Jun 9, 2005 11:37 AM
Hulk0202
Mar 6, 2002 08:22 AM
