HELP! Turning Over/Starting...
Old Jun 9, 2005 | 04:16 AM
5.7L89IROC-Z350's Avatar
Car: 1989 IROC-Z
Engine: 5.7-/-350
It used to turn over just fine, been sitting 4 a year now. New battery, starter solenoid, alternator. But I turn the key and it doesn’t wana crank, it doesn’t even try like it’s not getting the power it needs even tho everything else in about the car juice wise works fine because the battery is Good. But on the gauge in the car it’s losing like half the juice right when I try and turn in on. It takes a good charged battery and a 50 amp start hook up for it to turn over and when it does it runs pretty…didn’t drive to far tho…bout it sounded fine..normal...help please...pictures…what wires… what's the deal, where to look...what to do to fix it. Thanks!!
Old Jun 9, 2005 | 10:57 AM
Car: 1989 IROC-Z
Engine: 5.7-/-350
Anyone?? this beast is killing me everyday...I need some 1 on 1 help...really, everyone help me w/ this and then I can drive this thing...It's all I need...A Strong Start...!!!!!!!!!
Old Jun 9, 2005 | 11:37 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You need to measure the voltage drop on the battery when you try and start it. I see you changed the solenoid, but not the actual starter. If the battery is good and the voltage drop is high (couple of volts) it's either bad battery cables, a bad battery cable connection, or the starter motor is just plain toast.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
