Fuel pump voltage question
Old 09-07-2019, 06:44 PM
cougar20th's Avatar
Car: Black 88 Iroc Convertable
What is the voltage reading I should get at the three wire plug that is above the differential for the fuel pump.?
Old 09-07-2019, 08:37 PM
GeneralDisorder's Avatar
Re: Fuel pump voltage question
0v when the engine is off, 12.5v with the engine off and a fully charged battery, and 14.5v with the engine running and a working alt. It should run momentarily when you key-on, then stop and wait for cranking or running.
GD
Old 09-09-2019, 08:03 PM
cougar20th's Avatar
Thank you. Ended up the pump was seized. So I had to swap it. Odd thing was the strainer had mostly dissolved some of the strainer was left and its mounting parts. , the rubber seals had turned to a sticky mess. On a 7 year old pump.
Old 09-09-2019, 08:10 PM
Sounds like it may have not been Ethanol safe. Or was really poor quality. I generally use the Deatschwerks DW200 (255LPH) pumps - they have a kit for the C4 Vette that fits alright. I usually just buy a new pickup/sending unit assembly (Spectra seems the better of the two out there) and those also come with strainer bags, and hose, and such.
GD
Frozer!!!
10-12-2007 09:31 PM
Notplayn
08-25-2007 05:29 PM
Quick Reply: Fuel pump voltage question
