is this true? that 1.5 rocker arms on the intake and 1.6 on exhaust will give you hp
Old Jan 11, 2002 | 11:06 PM
chrisfrerick's Avatar
someone was telling me that it was better to use 1.5 rocker arms on the intake valve and 1.6 on the exhaust. he said it will give you more hp then running all 1.5 or all 1.6.
also with the mods below do you think i should of gotten the 1.6 instead of the 1.5 or am i already outflowing the maf capacity.
Old Jan 11, 2002 | 11:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends on the cam and heads.
On most street motors, you will gain nothing by downgrading either of them; i.e. the motor will make more power with 1.6s on both. However, in the top-end racing classes, they do that to reduce stress on teh valve train; they set htem up with the highest ratio, then progressively drop them until the car slows down, then go back up one step. That gives the best compromise between longevity and power.
Old Jan 12, 2002 | 02:32 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Actually, you'd want the 1.6's on the intake side. You make more power on the intake side. Most cams have more duration and lift on the exhaust side anyway.
Old Jan 12, 2002 | 11:23 AM
JAY87GTA's Avatar
The only way this might help is with the old style cams with the same lift and duration on both the exhaust and intake. Like Kevin said, most newer cams run more duration on the exhaust, eliminating the need to run different ratio rockers. Unless you have a set of heads with super crappy exhaust ports.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
happyhapka
Aug 15, 2015 04:42 PM
