Intermittent air conditioning blowing
Old Sep 17, 2019 | 01:52 PM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Hi everyone! I've been trying to figure out an intermittent a/c problem in my '91 Trans Am and am coming up with fewer and fewer solutions to try.
My a/c blows very cold and works fantastically. However, occasionally when I turn, or decelerate, or accelerate (or really anything), it'll cut out and completely quit blowing. Sometimes for a while. Sometimes for a second or 6. Occasionally jacking up on the brakes turns it back on. Other times it'll just start working again. I can't find a completely predictable situation or explanation.
Additionally, the blower motor will work 100% of the time without any problems if the vent or heat are selected. The cutting out only occurs when the a/c or defroster are on.
I can't find a loose connection anywhere. The climate control unit looks fantastic from behind. The electrical connections under the hood are all tight. But I'm starting to wonder if the clutch could be failing after seeing this photos in a jalopnik build article. Is it possibly spinning, catching, getting stuck, and starting again? https://jalopnik.com/heres-exactly-w...bmw-1834776367
Has anyone experienced this before or have any other ideas?
Thanks for the help in advance!!
Old Sep 17, 2019 | 08:00 PM
Re: Intermittent air conditioning blowing
Check the high pressure cutoff switch connector on the back of the compressor.
Ignore all the crap in those photos. Reality, to be sure; but if you don't have pieces falling out, that's not material to your situation.
Old Sep 18, 2019 | 11:42 AM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
Thank you for giving me a new nugget of information to investigate. I'll research that and likely come back with some more questions. Much appreciation!
Sneaky Neil
Oct 29, 2008 12:10 PM
chaosseeker
Sep 24, 2006 10:48 AM
91Firebird305
Jul 31, 2003 11:58 PM
johnnyformula
Nov 4, 2002 11:09 AM
