EGR solenoid
Old Sep 30, 2019 | 07:51 PM
Cheemo13's Avatar
Car: 1989 GTA
Engine: 5.7 tpi
EGR solenoid
Hey everyone. I'm new on this forum but have read alot of good info over time. I am now needing some advice of my own. Is a EGR solenoid from a Corvette L98 going to work and perfectly replace the fried one on my 89 GTA L98?? I managed to find some new ones at zip-corvette.com and that's the best I could do after much searching as this is a discontinued part.
Old Oct 1, 2019 | 10:05 AM
Cheemo13's Avatar
Car: 1989 GTA
Engine: 5.7 tpi
Re: EGR solenoid
Anyone???
Old Oct 1, 2019 | 11:15 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR solenoid
The c4 solenoid should work fine. It’s designed to mount on the t stat housing. The bracket might remove for coil mount.
or here’s another option.
https://www.thirdgen.org/forums/tpi/...-solenoid.html
Old Oct 1, 2019 | 12:38 PM
Cheemo13's Avatar
Car: 1989 GTA
Engine: 5.7 tpi
Re: EGR solenoid
So I have to ask...if the c4 solenoid should work fine....why are people converting to the caddy 4.9 solenoid??
Old Oct 1, 2019 | 12:53 PM
Engine: Lb9
Transmission: M20
Re: EGR solenoid
post 9
https://www.thirdgen.org/forums/engi...87-92-egr.html
Old Oct 1, 2019 | 08:12 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: EGR solenoid
I was finding the corvette one was very expensive. Looks like now most are out of stock for whatever reason. I did a load of testing on these years ago so my memory is a bit fuzzy on it. Some solenoids have normally open ports without power and the others have normally closed ports with no power.
87(?)-92 tpi solenoids function in the opposite manner than the TBI and the B-body LT1. I'm not sure about the Y and F body LT1 cars though I don't know why they'd be different..
The Cadillac 4.9 was the same as the later tpi fbody solenoid that I had. It was much cheaper and more available so I used it.
Old Oct 2, 2019 | 11:18 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: EGR solenoid
Use the VS25
I even have photos and a diagram on how to install it
Edit: I see TP linked to my thread already, nice.
Cheemo13
Oct 1, 2019 11:55 AM
Galaxie500XL
Sep 28, 2016 04:58 PM
Michigan F-Body
Jun 3, 2011 09:40 PM
jumpmansc
Aug 10, 2010 07:26 PM
Rob's 92 gta
Aftermarket Product Review
Aug 14, 2009 10:07 PM
