[MI] NEEDED: 87-92 EGR Vacuum Solenoid Part # 1997171
So my EGR solenoid has just failed and I come to find out that they are no longer available. Of course I am extremely pissed. I hope someone out there has one and can help me out. I just missed the biggest car show in the country (Woodward Dream Cruise) because of the stupidity of whoever decided to stop making this part!.
If you are not sure if you have the right one, attached is what it looks like.
Thank you,
Thank you,
Re: NEEDED: 87-92 EGR Vacuum Solenoid Part # 1997171
i think i have a used one sitting in the garage off a 91 tpi motor. far as i know it was working when i took it off. i'll look for it tonight and see what i find.
Car: 91 Z28 5.7
Engine: 5.7 L98
Transmission: A/T 700
Crap mine is bad also. And yes they stop making this item. Called Pepboys, Autozone, and Napa. No one carries it anymore. I searched the Oreilly website and found the part number EGR216. Called them up and same problem, they couldn't even order them. They just stop making them. This part is very crusial to the vacuum system and really makes a difference on the ildling of the vehicle. If anyone else out there has one that still works. Please let me know!
Car: 91 Z28 5.7
Engine: 5.7 L98
Thanks a lot Iroc Man. I did some research and started to do some research on my own. All EGR solenoid for this model 1997171 has been discontinued from GM and aftermarket companies. But GM builted a few cars during this generation with 5.7 TPI L98 engines. The Camaro, Corvette, Firebird, and Buicks. The only one I could find close to a match on the electric housing was the Corvette so far. I went ahead and ordered on Ebay from Corvette Central #: 304115. The only thing different is that the wire harness is backwards but should plug in. Also the brackets will neet modifying for mounting. If this works, I will also send my unit into 1 800 smog help. To get my original rebuilted. This way I can still drive my car while the original gets worked on. I will be posting later if this Solenoid actually works.
Car: 91 Z28 5.7
Engine: 5.7 L98
Okay this Corvette solenoid really works. I didn't have to hack the wires or pigtail to put this guy on. The only difference is the harness is in the opposite direction. Makes no difference the unit really works well. Remade a mounting bracket and that's it. Found a light aluminum bracket that was easily remodified at any hardware store. Hope this helps the lost and confused out there. 86-90 Corvettes EGR, highly recommended!
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I have 1 I'm going to tune out my egr pm me if u need it paypay
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
does anyone still need of of these, i have one that i don't need.
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
I just found out I need this dreaded part also. Who can hook me up with a working one?
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
Just got a brand new one from ecklers camaro. Installed it n works great.
Engine: 5.7/455
How much do you want for it? I can paypal you right away if it is in working order and affordible?
Car: 1991 red Z/28
Transmission: T5 swap
I need one also for my 91 TPI. The one I do have is for the something else. I just found the Eklers site. http://www.rickscamaros.com/camaro-s...1985-1992.html
Car: 1991 red Z/28
Nevermind, I pulled that big flat hose connector thing off and its the same one that Firechicken posted a pic here.
Car: 1987 Trans Am GTA
Engine: 350 TPI modified
Transmission: 700R4 modified
i need one badly. anyone still have one? i know this is an old post, but im in need of a working one. please PM me and let me know how much. Thanks alot.
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
I tested on my 95 Chevy Tahoe L05 350 tbi did not throw any codes so it must work
pm me your address and I will get this out to you right away did not get a chance to check postage but it can't be over $10-12 including the envelope ..
Thank you very much. I sent the $$$. I appreciate this very much.
Engine: 5.7/455
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Guess I'm going to have to get one too living here in CA with my luck, it's going to fail.
[quote=blackfrontier;5829631]I will look for it when I get home tonight from work[/qu
Any luck? Sorry for being impatient. This has been a long journey.
Engine: 5.7/455
EGR Vacuum Solenoid Part # 1997171 Needed
I am looking for an EGR Vacuum (Regulator) Solenoid for a 1991 Pont Trans Am. It has 5.0L (305) V8 VIN: F motor. The part number I need is 1997171. Does anybody know where I can source one?
Blackfrontier - If Jds141 has not purchased, I'll take it. Let me know.
Thx
Thx
Car: 91 TRANS AM GTA WS6
Transmission: T5 5speed
Re: EGR Vacuum Solenoid Part # 1997171 Needed
Old thread, but I need one of these for my 91 GTA 57 L98. Anybody got one still?
Engine: 5.7/455
I would expand your search by looking for the one used on corvettes those years. The mounting bracket is shaped a little different but can easily be made to work and is more plentiful. I used one on my 87GTA and worked fine. The solenoid guys are identicle. I think that part is still available for like 68 bucks but I got a used one on eBay
Engine: 5.7/455
Transmission: Pro-built 700R4
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
im pretty sure i have this and im in michigan too pm me if you still need
Well I guess I'll ask too, does anyone have this part for a 92 5.7?
Hopefully someone still has one laying around. Would really like to get this fixed on mine.
