87 LG4 Alternator Belt
Old Oct 7, 2019 | 07:44 AM
DoctorStoopid's Avatar
Car: 1987 Trans Am
Engine: LG4 305
Hi all,
I feel like the biggest idiot but how do I access the alternator belt on an LG4 to replace it? The AIR pump belt gets in the way and I don't see how the AIR pump is adjustable to pivot the belt away like the AC compressor and alternator is. Do I really need to remove the water pump pulley to get this thing off like I'm thinking, or am I missing something obvious here? Thanks1
Old Oct 9, 2019 | 12:23 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 87 LG4 Alternator Belt
Loosen the three bolts that are circled. You can then loosen and remove the AIR pump belt and access the alternator belt.
Old Oct 9, 2019 | 02:31 PM
Drew's Avatar
The easiest way to get the V-belt off the smog pump is to crack the three bolts holding the pulley to the smog pump loose, then loosen the adjuster bolt and pivot bolt. Finally remove the pulley bolts and the belt comes right off. Otherwise, there usually isn't enough room to remove the belt from the pump.
Old Oct 14, 2019 | 09:57 AM
Car: 1987 Trans Am
Engine: LG4 305
Awesome! I was missing that lower bolt on the AIR pump and that's why I couldn't wiggle it. All set now! I have a new problem however:
Before I replaced the squeaky alternator belt, it would sometimes run at 8 volts (when it was slipping) but once it caught back up it would constantly read right at 13. Now, with my new belt, there's no more squeak and it never drops at idle, but the max output I see on the gauge is always a couple ticks below 13. Could this really be the fault of the belt? Where should the needle sit at cruise?
apie2546
Jun 14, 2017 02:17 PM
jaredc91
Oct 29, 2009 09:24 PM
Lantern2745
Jun 14, 2009 10:27 PM
ddn69
Mar 26, 2004 02:40 AM
wizard
Aug 29, 2001 08:53 AM
